TurboJoe3.8
Senior Member
- Feb 19, 2003
OK- this is probably gonna be a long post so bear with me
My Gn's mods are in my sig below
Took the GN to the track this weekend for the very first time, made six total passes- first pass with Razor's akly control blue gain knob set at 3/4- 93 octane only- boost at 23lbs- 2.75/60 BFG drag radials- 25lbs right/10lbs left air bags- no snubber- scanmaster- fuel pressure at 43lbs line off- timing 21 degrees 1/2 and 19 degrees 3/4- trans selecter in drive- left at 3lbs boost (car was trying to push thru lights!) trans automatically shifted at 5200rpms 1/2 and 3/4
60ft- 1.96
1/8 mile-8.23
1/8 mph- wasn't working on left lane
1/4 et- 12.84
1/4 mph-104.94
02 reading in high gear on scanmaster- .786
16psi in the tires
no knock
second run I let my 21 year old son make his first pass ever and he didn't clean the tires off very good- spun real bad
timing same as first run
60ft- 2.19
1/8 mile-8.62
1/8mph-85.77 (working in right lane)
1/4 et- 13.38
1/4 mph-102.84
02- .783
16 psi in the tires
no knock
I got back in for the third run
bumped timing to 23deg 1/2 and 21deg 3/4
60ft- 1.90
1/8 et-8.34
1/8mph- none
1/4 et- 13.17
1/4mph-99.80
02- .808
16psi tires
no knock
my kid got back in for the 4th run- he left soft
adjusted fuel pressure back to 38lbs
timing same at 23deg 1/2 and 21deg 3/4
60ft-- 2.26
1/8 et-8.90
1/8mph- none
1/4 et-13.81
1/4mph-98.39
02's- .806
16psi tires
no knock
I took it down on the 5th run
this time I trimmed the fuel in the chip from 128 to 118
bumped timing to 25deg 1/2 and 24 deg 3/4
60ft- 1.91
1/8et-8.20
1/8mph-86.34
1/4et-12.94
1/4mph-103.53
15psi in tires
02's- .796
no knock
Let my kid take it down next for the 6th run
left everything the same
he still left too soft
60ft--- 2.23
1/8et- 8.64
1/8mph-85.87
1/4et---13.39
1/4mph-103.96
15psi-tires
02's- .790
no knock
OK- I know the 60 ft times were bad- I think the reason that I couldn't hold any boost at the line was because I got the back brakes too hot when I heated the tires. What I don't understand is why it ran so rich even when I kept trimming back the fuel at the regulator and in the chip and it layed down on the top end ( picked up less than 18mph from the 1/8th to the 1/4). I think even with the poor 1.9 60's it should still run mid to low 12's with this combo.
Even tho I'd had the car for two years, I new at tuning this thing
what do you guys think?
Thanks, Joe
60ft- 1.96
1/8 mile-8.23
1/4 et- 12.84
1/4 mph-104.94
16psi in the tires
no knock
60ft- 2.19
1/8 mile-8.62
1/4 et- 13.38
1/4 mph-102.84
02- .783
16 psi in the tires
no knock
60ft- 1.90
1/8 et-8.34
1/8mph- none
1/4 et- 13.17
1/4mph-99.80
02- .808
16psi tires
no knock
60ft-- 2.26
1/8 et-8.90
1/8mph- none
1/4 et-13.81
1/4mph-98.39
02's- .806
16psi tires
no knock
60ft- 1.91
1/8et-8.20
1/8mph-86.34
1/4et-12.94
1/4mph-103.53
15psi in tires
02's- .796
no knock
60ft--- 2.23
1/8et- 8.64
1/8mph-85.87
1/4et---13.39
1/4mph-103.96
15psi-tires
02's- .790
no knock
Thanks, Joe
