Buick Beginner
Where is my $$$ going?
- Nov 9, 2001
Good Day to All,
Well I put my motor back in the car and fired it up yesterday. After a few tries she ignited and I waited about 10 seconds before taking it up to 2000 RPM's for 30 minutes. (Cam break in proceedures). The cam is a Postons GT107, it's about a 202/202 cam, pretty mild. About 10 minutes into the break-in my buddy notices that my drivers side header is glowing orange. Not enough to light up a dark room, but definately glowing. The passenger side looks fine. We went ahead and shut it down, let it cool for about 5 minutes, then re-started it and ran it back up to 2000 RPM again, so the cam break in took about 45 minutes because of shutting it down to cool and starting it back up. I'm trying to pinpoint the problem, I don't think it's normal to have a glowing manifold at 2000 RPMs. Now, with that being said, does anyone think the cam sensor could tie into this? I personally don't like the instructions on the cam sensor installation, so I'm not 100 percent sure it's right. The car runs smooth, in fact I would have thought I got everything right if it were'nt for the manifold. ( Well, my oil pressure is too low, but I don't think that's related, I'm working on that issue as well). BTW, at idle the glowing goes away. Just for everyones info. the pistons, rings, bearings, etc. are all new. Does anyone have anything to offer? I've been told that the cam sensor times the injectors, how would you know if the cam sensor was off a degree or two? Thanks - BB
