- Feb 18, 2006
Some get lucky I guess...
Scott,
They live just fine when set up right and supplied oil. If you run them dry they won't last.
Rick
What are you guys finding out is the best way to get oil to the gear - if you have a billet roller without cam supplied oil?Scott,
Rick
Many sbc and bbc guys did this into the block cam journal behind the timing gear!A .020 hole in the oil gallery plug does the trick.
That was to lube the ft face of the block/cam gear surface.Many sbc and bbc guys did this into the block cam journal behind the timing gear!
Any pics of this being done, still waiting on parts, so I got time.A .020 hole in the oil gallery plug does the trick.
which one, I'll have my machinist do it since he has my block. ThxA .020 hole in the oil gallery plug does the trick.
Earl Brown and Jerryl seem to have this thing down pat? This is Jerryl's vid so Maybe he'll do a how to write up??
Does the hole affect oil pressure? Should I run heavier weight after?It makes no difference what plug gets drilled. Either one will get the job done.
