Kaine Beedenbender
- Jul 14, 2013
As you might of read my other thread, i bought what i thought was a decent T-Type off of eBay. It turned out to be a bit worse than i thought. Today i tore into it and replaced all of the vacuum and gas lines. I bought a rebuild kit for the turbo.
- While trying to replace the PCV grommet it was very hard and brittle and half fell into the intake. Do i need to remove the intake or can i leave it there? I cant see it even with a scope.
- I tried rebuilding the turbo but the bolts were so rusty they all snapped and the turbine wheel is bad. Anyone know where i can get a good used turbo for reasonable? If i were to upgrade now what do you recommend? I need something that will run stock now and that i can turn up later.
Thanks for any suggestions.
