No, the GN motor is not considered a series I. It it still called just the 3.8 Buick V6. The series I is the front drive 3800 engines from 91-95. The holes on the sides of the block were carried over from the I to the II so the engine mounts will bolt up from the series II 3800 Camaro, Firebird. The only problem with that is the accessory drive setup may present a challenge. The series I has a 1" taller deck height than the series II and as far as the supercharged versions go, the I uses the inner belt to drive the supercharger and the II uses the outer(1st belt in front) to drive the supercharger. Do you want to use an automatic or manual? For an auto you can use the 4L60E or the non electronic 700R4 from a V6 Camaro. The flywheel from a Series II can be used on the Series I, but will have to be rebalanced in order to use a manual tranny.
