While I haven't seen it in person, It makes perfect sense.. Alcohol is VERY hygroscopic, and as such is EXTREMELY miscible in water (why we have to go such trouble distilling it to separate the water out) while most petroleum distillates (gasoline, etc.) are almost completely immiscible in water and should separate very easily. If you can get your hands on a separating funnell it will make the job a LOT easier, though any large tall funnel you can see through with a relatively small spout should work... the funnel and small spout make it easy when you get to the water/alky - gasoline boundary to get all the good stuff and none of the bad. Typically if you're trying to separate a substance from a solution, you will "wash" the solution several times to make sure you got it all by taking the gasoline, and adding more water, and doing it all over again to get all the alky out... but since the first pass is probably pretty effective, and any successive washes would just dilute your end product (alky) with more water, you probably don't need to.
