Car stalls sometimes
djj624
Have an 87 T. Pretty stock, just ordered a 255 fuel pump with hot wire kit and a tt chip. Problem is it stalls sometimes when coming to a stop. My rpm is at 725, tps is at 44, and iac is at 57 these numbers are at idle warmed up. Also I'm getting a code 32 egr. Don't need the egr is there way to get rid of it and clear the code?
Galaxy S7 Edge
If your getting a code "32" the EGR solenoid is most likely leaking which will cause the engine to stall at idle by leaving the EGR valve open. You can plug the vacuum line going to the EGR solenoid from the intake manifold. That should get rid of the stalling problem. To clear the code just disconnect the ECM power line at the battery for about 15 seconds and then reconnect.
