if you are talking about the plate to the floor there arent any nuts and bolts
just little 9/32 (7mm) headed screws with integral washer
dont know how else to explain it , it goes on with short screws
the screws look like the screws that hold the fan relays on driver fender ....but shorter
can someone post a pic i should have them in my box of hardware.
all the screws are the same size
believe me it doesn't use any other hardware
best i can do with phone
the little screws with larger washer are the sheild screws the one in left upper is the screw for relay so you can compare
yesterday i sent you the shield with 4 black 9/32 socket head screws with the washers about 3/4 inch longWas unable to open the pic, after looking under car again, you are correct about hardware. Thanks again
try this pic
