K KWIKR 1 Active Member Joined May 25, 2001 Dec 4, 2002 #1 I cc one chamber in each head and they came in at 43.2cc . With TTA pistons and a stock head gasket any ideas on my final CR ?
J jamesmac Member Joined Nov 12, 2001 Dec 4, 2002 #2 Nope, but you are using those pistons in that motor. Right. James
S Steve Wood Active Member Joined Jul 18, 2001 Dec 4, 2002 #3 did not try to calculate it as one needs deck height. Probably a bit under 8-1.
K KWIKR 1 Active Member Joined May 25, 2001 Dec 4, 2002 #4 yep , using those TTA pistons James . Steve ,once the deck height is factored in. that's most likely in the ball park of where I want to be .
