I recently picked up a brand new snow performance alky pump. But this pump uses push to connect fittings on the pump head. I really wanted to run -4 AN Teflon hose, because I'm not a big fan of the push to connect tubing. No real reason for that, although that I just think it's flimsy. Also, I already have an M15 nozzle set up in my up pipe, so it will be easier to use the braided hose without using a bunch of adapters to adapt to the tubing
So my question is, has anyone converted a push to connect pump to use an braided fittings. I see Devil's own has a pump head with 3/8 npt ports. It would be cheaper for me to buy the pump head, and then to buy the other push to connect fittings to use the M15 nozzle.
