turbo nasty
Turbo Dojo / MNTR
- Jul 19, 2001
Working on a GN with fuel delivery and risen rate issues. Found the most random piece inside fuel psi regulator......a piece from inside the fuel psi gauge! Thankfully it didn't fall down and block flow to the number 1 injector. Piece removed and all is good. My thoughts are the gauge is on the fuel rail and exposed to a lot of engine vibrations and the piece simply vibrated loose. Check those gauges!
