1005 Cubic Inch V8
LOUS 2011 1005 cu. in. V8
SPECIAL EDITION GM HEMISPHERICAL HEADED ENGINE
WITH 2150 + NATURALLY ASPIRATED HORSEPOWER !!
*** The First Ever 1000+ Cubic Inch V8 Drag/Street Racing Engine***
This new edition is for Tim Pidcock ,alias ( mean chicken ) will be this 1005 cu. in. 2150+ Naturally Aspirated Horsepower V8 Engine that will feature Lou’s New fully in-house CNC ported Special Edition GM Hemispherical Cylinder Heads with the Ultimate Pro Stock Porting, for maximum Horsepower. Other components will feature SAR/Custom Titanium valves, PSI springs, SAR Special Billet aluminum block with 2 inch raised cam, to accommodate the Custom 70 mm camshaft, Sonny Bryant Billet Crankshaft, GRP billet Aluminum rods, Mammoth SAR/ custom pistons, with special ring package, SAR/CE 1.062 keyed lifters, 1.031 tool steel taper-wall pins, SAR/T&D/Jesel shaft mounted rocker system, Jesel belt drive, Custom Dailey 7 stage Lightweight dry sump oiling system, ATI balancer, MSD Ignition, SAR Sheet Metal Pro Stock intake, Featuring SAR/ Accufab Throttle Bodies, Custom Big Stuff EFI, Sonny's Billet valve covers, and a MSD Pro Series Starter to turn over the 1005 Cu. in. Beast. Current development for turbochargeing is under way. Blocking progress is the logistics of turbo placement. Mr. chicken has suggested some available trunk space & is under consideration.
