blackgn231
Money pit
- Mar 28, 2007
I am not sure what chip to run a street / alcohol chip  or alcohol chip/? I have stock block roller cam, ported and polished heads bigger valves , port matched intake , 3- inch down pipe  PTE stock location intercooler, TA-49 turbo, bigger fuel pump, hot wire kit, 160 thermostat, bigger throttle body, stock  convertor. I don't race my car going to install akly kit and 60 lb injectors,. The guy doing the install said bosst around 16 - 18 my friend said 20 -23 . The install guy Fred  Smith said since, I was using a stock  MAF that timing needs to be increased to help with the burn ,I know the alcohol chip increases timing. So just not sure any help would be great. Does most guys run 100% alky all the time on the street or mix it with water?
