chips
  • Thread starter Thread starter used2hav1
  • Start date Start date
U
used2hav1
Guest
need some suggestions on some good race and street chips for my combo.i'm currently running RA's street and race chip which work fine, i might add,but i really want to know what else is out there for my combo(see sig) TIA
You won't go wrong with chips from Jay Carter, Jim Testa, RamChargers, Joe Lubrant. Or stepup to the MaxEffort Thumbwheel setup.
Paul
Get an extender, and then a WB O2 sensor, or EGT gauge.
Hope that is an Translaor Plus.
I have a similiar set up to your's, and thought I had things close to right. Plugs looked perfect (This is with 30+ years of looking at plugs).
Hooked up a wide band and found I was at 12.8:1. Couple passes and got down to 11.6, and the difference was amazing.
In a million years never would have thought I was that far off.
Oh, and in enrichening boost dropped a little from lower EGTs, and then dialed the boost up some more and added a tad more fuel, and well, the car is running well. Real Well <G>
