Will email them shortly.Servo uses original pin and inner and outer springs.It does not use the steel 3rd piston that installs inside the 2nd piston.From inside out orientation is 1,small return spring,2 stock servo pin with clipped on cushion spring support,3 large cushion spring,4 billet 2nd piston,5 billet servo cover 6 original retaining ring.
