Hello,
With the classic FAST is there a way to calibrate the TPS to read 100% under WOT? The Throttle Position Sensor was set with a meter within parameters and reads correct on the meter but the FAST sees only around 87% @ WOT and 7% at idle. I know the XFI you can calibrate that sensor. Just checking to see if the Classic I just have to accept that at 87% I am really at 100%?
Shev
Shev
