bob86gn
Senior Member
- May 24, 2001
I am in the process of putting a Detroit Speed Suspension on my 87 GN and I figured I should clean up the exposed parts of the frame a little bit and POR-15 it. The area under the upper A arm cleaned up pretty good with some brakecleen but the rest of it has something else on it. Not sure what it is but it doesn't come off easy. Do you guys have any secrets for cleaning and prepping the frame. Obviously the body is still on it so it isn't as simple as sandblasting or dipping.
