You also want to get a new GM carrier pin bolt...comes with loctite on it... they have been known to snap when you try to remove them...I also replace the carrier pin...not really necessary but while you're in there...why not...the job can be done easily on the car...no need to remove the carrier...hardest part is getting the spider gears back in...S spring can be a little bit of a pain too...
