CompCam Solid Billet roller set
ALETTOCO
I have a used CompCam Solid Billet roller set that I bought from a board member at bowling Green this past year I got everything with a set of heads I’m going to use the heads with a hydraulic roller. The springs are in good shape. I had a shop check them out the retainers are titanium the springs are rated at:
Seat Load: 200lbs. @ 1.825''
Open Load: 500lbs. @ 1.265''
Coil Bind: 1.100''
Rate (Lbs. /In.): 550lbs
The roller rockers looks new they are 1.55. I believe the pushrods are made by White bros and they are 5/16x.116 and 9.450”. I’m not going to be using anything on top of the heads so I’m selling everything you see from 450.00 or trade for stock stuff. Call me if any question anytime. the cam is big but I was told it can be reground with no problem.
Bob@alettoco.com
561-703-5795
More Picutures and Info
