captndave737 Well-Known Member Joined Feb 14, 2006 Jun 8, 2017 #1 Can 10:1 compression be done safely with iron heads?
S ScottHeidinger Active Member Joined May 2, 2015 Jun 10, 2017 #3 CGASTON said: Yes it can Click to expand... Are you running that on 93/alky or E85 and how much boost are you running? Sent from my iPhone using Tapatalk
dank GN BlackArts Automotive (661)993-8277 Joined Jan 11, 2009 Jun 10, 2017 #4 I'm at 10.5 :1 runing E85 with 20lbs
captndave737 Well-Known Member Joined Feb 14, 2006 Jun 12, 2017 #5 Ok, Thanks. How about if i'm running 93 and Alky?
S ScottHeidinger Active Member Joined May 2, 2015 Jun 12, 2017 #6 High Compression VS Low Compression Opinions https://r.tapatalk.com/shareLink?sh...mpression-VS-Low-Compression-Opinions.445313/ Sent from my iPhone using Tapatalk
