control arm bushings
ED Turbo6
What is the best vendor for front control arm bushings and who has done it there shelf what tools are need :confused:
U can get the rubber bushings from any parts store. I've only done the uppers, not the lowers cause I'm scared:rolleyes: . Haynes manual has a good description of taking the control arm out. All you will need is a vice, air chisel, and a torch for just in case. Put the bushings outside or in the freezer when you start the project, they'll go in easier.
I have a complete front energy suspension poly set (uppers and lowers for both sides) 60 to your door, Ryan
