Hmmmm 27lbs of boost on basically a stock motor. I did a comp check at 5 where within a LB of 140. # 2 however was about 117. The plugs all looked good, the oil looks fine, no smoke at all, And no bubbles that I can tell in the radiator. Seems to have developed a slight miss at idle but other than the coolant smell when I first start it up and the lower comp in the one cylinder. Any ideas? If it is a blown HG I am going to go ahead and get the heads P&P with bigger valves while I have them off.
