correct swaybar endlink length?
Turbo6Smackdown
I switched out my front stock swaybar for a better 1 & 3/8ths inch swaybar, and i threw different end links in there. Well, I'm going back to stock, and was wondering if they used different length end links or not. anyone know? if not, whats the correct end link length?
I sell 34mm and 36mm hollow bars and they all use the stock lenghth end links so you should be able to reuse your end links.
Yea, just the piece of rolled tubing in between everything else..
Though, sometimes, i doubt 3 & 3/8ths was ever correct.. I think the stock link spacers were about 1/4 to 5/16ths inch too long, as the energy suspension website calls for the bar to lay parallel to the control arm once installed. 3 & 3/8ths inch spacers technically dont allow for that.. At least on mine they don't...
When I put my 36mm bar on I just cut the new link spacers down until they were parallel.
Sounds like I had better crawl under and measure 1st. Thanks everybody. Better safe than sorry.
