John at J&S
- Jun 19, 2002
Craig: I'm working with a Porsche guy using your system. Harv does his tuning.
It's trggered from an MSD flying magnet crank trigger, and driving an MSD 7.
Am I correct in assuming that the inductive delay in the Global Parameters window is to compensate for the slow turn off of an inductive discharge ignition, and not the delay of a magnetic pickup?
Since he is running an MSD, shouldn't the delay be changed from 96 usec to 5 usec? If it's not changed, won't they have more timing up top than they think they have?
If we add our knock controller in series, we just add its delay to whatever number the tuner has for inductive delay, right? So if the tuner wants to keep the value at 96 usec, and our system adds another 50 usec, enter 146 usec?
I think Motec has a similar setting, and they call it ignition delay. That term seems less confusing, and easier to explain to the tuner.
