Boostin TA
- Aug 27, 2005
Hey Guys, I need some help on this one. I had put my car on consignment last July to be sold and went to pick it up only to find that my batt was completly dead and now the car is dead in the water with a crank no start situation. I have a MAFTPRO installed and scanmaster. The scanmaster will only light for a second and then go out. The Maftpro I dont think is reading PCM data either as it shows no rpms when cranking the engine over. Pulled a plug wire off the coil and has no spark. I tried switching out a PROM chip but that didnt help. I did notice that the cooling fan relay looks melted. I also checked continuity from the pcm connector to the battery and apears good. I couldnt get a good enough connection to check from the connector to the pcm though. Any ideas on where I should start or what to look for?
