dr_frankenstein
Mad Scientist
- Mar 17, 2008
Ive looked far and wide both here on the board and on the interweb and i cannot find a defined answer, So im calling on AC experts here to gimme some insight and a hand.
I need custom AC lines for my application because I have a remote condensor. So my lines will be in total over 9 feet long.
to me this doesnt sound like a good idea to have a ton of barrier hose running underneith my vehicle where its exposed to more elements and the road then normal. So I wanted to plumb these lines in Aluminum or Steel. I will be brazing/welding the needed ends to connect the lines to the short sections of barrier hose with the proper O-ring fittings.
And this is where the question is.
What kind of aluminum/steel line is needed?
Can AN fittings be used?
Can Compression fittings be used?
What size should my lines be to and from the condensor?
Does it matter where the dryer is located? (low, high, close to compressor etc etc )
Thanks All
A.j.
Thanks All
A.j.
