- May 28, 2001
The "runs ok at 90% throttle" comment has me wondering: Is the TPS failing? Key on, engine off, slowly apply throttle to WOT. Watch the SM. TPS go smoothly to 4.5v?
The pump dropping to zero immediately is not normal.That line is pretty hard, so it's hard to pinch. So I capped it (screwed in a big bolt...very tight fit). I turned on the ignition/power to the pump, and it went to 52. I did it again a couple minutes later and it went to 53.
~But I just noticed something that might be important. When putting power to pump (ignition on), the instant the pump shut off, the fuel pressure dropped back down to almost 0 within a couple seconds. Is that normal?
I know, I'm concerned about low O2 MV's. I check the Scanmaster after every run. The lowest I've seen during these test runs is 789 (most are low 800s). Don't you think that's saying I'm not really anywhere near an engine damage danger zone?
Apply regulated pressure to the vac/pressure port of the fuel pressure regulator . Start at 10psi , turn on the pump with the prime wire with 0 air pressure , check base psi , apply 10psi & should go to base + 10 . Go on and increase air psi and FP should rise 1 for 1 up to at least 70 psi . No driving required . Sam
Let me guess, Accufab adjustable fuel pressure regulator?
Can you take a picture of the top of the coil pack, I have an idea.Can't say...came on the car when I bought it. Attached is a photo. Can anyone tell by this shot?
If you suspect the fuel pump you need to flow test the fuel pump at the pressure you are looking to run. With base pressure at 52 and you want to run 20 at the manifold you would flow test at 72psi. Speculating about a fuel pump and not actually flow testing it is a waste of time. So it's time to get off the internet and start flow testing. You find out what your pump should flow at a given pressure/voltage and compare to what you actually have
Sorry to keep you out of the loop, I'm just trying to see if a wire was on the wrong cylinder. Double check them if you're not sure.See attached.
I'm happy to do it, but I do like knowing what people are thinking before I go out and do things though.I was asked to pinch test the return line, not knowing what I'm looking for. Did that, and still don't know why. Helps us all learn when it's explained.
You didn't do a pinch test the correct way. You need to block off the return apply power to the jumper wire and see what it does. Should go over 90 imop
If that checks out jump the wire and start applying pressure to the top of the regulator and see what the pressure does. I'm going to guess this is the issue.
A dent tank isn't the issue. Why buy another pump when a new one was just installed. You said you added a ground with no change and I don't belive this is the issue anyways. I'm going to say it's the regulator but without you doing test we don't know.
Also do you know how to change the regulator?
