With the timing locked I have run 25 , 26 , 28 , 30 , 31 , 33 & 34 . at 25 it is soft everywhere and as I give it more timing it goes quicker. but note that more timing will pick the 60 ft up much more than 330 or 660 . if say the 60 picks up .06 the 330 may only pick up .04 and the 660 maybe .03 , so while the ET is quicker the top end HP is less and retarding the timing does nothing to help this. looking at the valve spring issue , I now think that maybe advancing the timing picks up the HP which in turn raises the stall speed and the RPM at any given point on the track and puts it above say 6500 sooner ( which it doesnt seem to like ) so the HP down track is less , for more time !!! did that make sense ???
