Jul 24, 2019 #1 C carguy Member Joined Oct 18, 2005 Messages 237 When putting dipstick it is tight.do you push it in till it stops or tap it in till it stop.is there a stop that keeps it from going in any farther?
Jul 24, 2019 #2 TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Messages 6,689 Try turning it 180 degrees and reinstall. Mine is sticky one way, fine the other. Makes the "ENGINE OIL" read upside down.
Jul 24, 2019 #3 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 Are you talking the dipstick or the dipstick tube?
Jul 24, 2019 #4 C carguy Member Joined Oct 18, 2005 Messages 237 mikestertwo said: Are you talking the dipstick or the dipstick tube? Click to expand... Dipstick tube
Jul 24, 2019 #5 TurboTGuy Gray Beard Member TurboBuick.Com Supporter! Joined Sep 24, 2010 Messages 6,689 The dipstick. If you're talking about the tube there is a flare about an inch and a half up on the bottom end of the tube that keeps it from going down/in too far.
Jul 24, 2019 #6 M mikestertwo Well-Known Member Joined Sep 13, 2006 Messages 5,249 Just push it in until the ridge on the tube contacts the block. The ridge on the tube will stop it
Jul 24, 2019 #7 ek02 Well-Known Member Joined Jan 31, 2008 Messages 1,226 If you have a girdle, it may be hitting it. If not, just tap it in with a plastic mallet.
Jul 24, 2019 #8 E earlbrown runs with scissors Joined May 26, 2001 Messages 7,541 carguy said: Dipstick tube Click to expand... Put a tight fitting wrench on the lip at the base of the tube at the lip. Then hit it with a swatter. Make sure to put some thin sealant on the tapered end of the tube. I prefer Yamabond.
