Bought a used Reds Double pumper off another board member. When it showed up the main pump feed harness was jacked and the secondary harness with hopps switch was not included
Anyway I plan to use my KB Boost a pump to run the primary pump. How is the secondary pump supposed to be wired from the tank forward? Is it normally fed from the lug on the back of the alternator and then through the hobbs switch to secondary pump? Normally gounded to the fuel tank or.....?
