deezdad
Jackie's cashing in on your wretched disfigurement
- Mar 25, 2005
180 t-stat recommended even with a fmic in front of it running both coolers w/ stock fan?
SignUp Now!I'm on it! That's nice lookin too!Yes sir, it has both coolers.
That is what was recommended to me. I have a 180° T-Stat. When I get mine it was suggested to keep it in.180 t-stat recommended even with a fmic in front of it running both coolers w/ stock fan?
ALRADCO.com
Choose with or without coolers. I ran with oil and trans cooler and it was AWESOME! Keep the 180 stat in there.![]()
Got the radiator on Monday, I am not easily impressed and opened it up to see how dinged up and how many fins were bent. I pulled it out of the box and was jaw dropping astonished! And that was only how well it was packaged! It was packaged up in a nest of shock resistant foam, all around. I pulled the packaging off and my eyes really widened. This thing is a piece of work and is extremely beefy! I can't wait to get it in. Needless to say, I am very impressed. I think I will stick a 180 Thermostat in it. I did install a billet neck so it should pop right back outI think I will install the alky while I have a bunch of stuff off the car. Should give me more room. Sorry for the big ass pics, I don't know how to fix it. Thaks ALRADCO!
View attachment 227074 View attachment 227075 View attachment 227076 View attachment 227077
Any 4th of July specials??![]()
I initially did, but ended up cutting out most of the 1/16" steam hole when I had to cut down the Stant t-stat to fit the hole in the block. I didn't bother re-drilling it again because the previous 180-degree t-stat wasn't drilled, and the same problem happened with both...puking coolant all over. Since I never even saw bubbling action in the coolant with the rad cap off while running the car after the t-stat R & R, and the top hose never seemed to have pressure in it, the signs seem to be pointing to the rad being the problem.Did you drill a steam hole in the thermostat? Sometimes this will help to get things flowing. You may just need to "burp" your system since you opened it up.
Thanks for the correction on the trans cooler. I agree - the air that's in the block needs some way to escape. Drilling a hole in the t-stat is an easy way to accomplish that.F body radiators have trans coolers. Sounds like you have a large air bubble in the engine and need to burb it.
If hot water never reaches the t-stat, it will not open. If the t-stat never opens, you won't see circulation in the radiator.
I would pull the t-stat altogether to see what happens before spending the money on a radiator.
You can get an F-body radiator fairly cheap from the parts store, but you will lose your oil cooler and transmission cooler. It's not exactly a drop-in replacement from what I've read here, but it's pretty close and a less expensive option. Many don't operate with an oil cooler anyway, but I wouldn't be caught dead without a tranny cooler.
How do you program in to have the thermostat come on at 167?do you have to have the TT chip or can this be done on a stock chip?on (say for example) a 85 degree day.... will a stock fan on a alradco radiator be good enough to keep up with a 160 thermostat? (and I'm using a tt chip with fan programmed to come on at 167ish degrees
There's no place to put a gauge that's post-pump/pre-cooler. If the gauge is around the brass block, it reads pressure after all the bypasses and coolers and stuff.A bigger restriction would cause the pressure to go up.
Of course that depends also upon where the gauge is plumbed etc.....
X2!The fittings on the stock oil cooler in the radiator are larger than the trans fittings so it is logical the oil cooler flows more than what the trans cooler would be able to. Using the trans cooler to cool the oil doesn't make sense. Some aftermarket trans cooler catalogs say "not for engine oil cooling". The aftermarket oil coolers have much larger inlets.
