Brian Verson
- Jun 19, 2001
I'm needing some information on a Dual Pump intank setup. I'm looking at the ss340m Walboro pump from racetronix. They r as of no help when it comes to answering an e-mail. So I'm turning to you guy's for the answers i seek. I have the hotwire setup from caspers w/the relay. Will it supply enough puwer for both pumps or is there a different wiring setup i may need. I'm upgrading the supply and the return lines. Is a 8an feed with a 6an return line big enough or do I need to go with a 10 an / 6 what I need. What do I need to do with the fuel pump hanger to be able to get the proper amount of fuel into the line so I dont run lean . Help. Thanks
