I'm not sure if it's my assembly techniques, lubrication mods or what, but I've been using the same Milodon geardrive unit since 2005 in two different motors. The latest engine has been together since 2008. Lots of testing. Lots of passes.
My setup makes zero noise.
I do take special pains in fitting the geardrive mounting plate to eliminate any clearance movement to the mounting bolts. Kind a like mounting the plate on tight fitting alignment dowels. I also feed a spray of pressurized oil to the idler gear bearing. Red loctite is all my setup has needed.
Do away with the flat roller type idler bearing and use the ball bearing style with it's simpler mounting shaft. No little screws to come loose with that style. Just one honkin shaft with a large thread, loctited and torqued to the mounting plate.
I don't know how some of you are ending up with a noisy setup. I dare anyone to even use a stethoscope and try to tell if it's any noisier than a chain in my engine.
