Dyno Numbers
fast86gn
Texas Moderator
Staff member
Made it out to Speedtek Performance on Saturday for a little Dyno action I was still set in kill mode from the previous night of racing at Redline Raceway.
I made 3 runs total the first two were through the mufflers and the last run was with open exhaust. They were all with JC 110 chip with 21-23lbs of boost.
1st run
HP 341.3 Torque 448.5
2nd run
HP 343.0 Torque 450.7
3rd run
HP 371.0 Torque 491.6
Needless to say I was very happy with the numbers it produced and especially on a muggy sticky day at about 84 degrees outside.
My set up. Stock block and heads, TA49, Stock IC w/big neck, THDP, Bluetops, power plate, K&N, XP Pump, adj reg & hot wired, JC 110 chip.
I'm afraid to take mine on full kill.I might be embarrased if it makes alot of power and I cant go any faster than I have,or vice versa makes less power than it should.
