I had my fast system tuned on a dyno last week and I am curious as to why the torque was so low. The best pull was at 597 hp/ 495 lbs at the wheels, maximum 6k rpm. The boost was 24lbs and the timimg was a safe 18 degrees and A/F at 11.05. Would the small cam 218/212 be the reason? Turbo is a t76 q trim with a 3.5 downpipe. Motor is a 280 inch stage 2 offcenter with gn1 heads. Champion stock style manifold with worked stock TB and hemco plenum.
