You have to order a TT SD2 chip . Since that's a maf less chip (speed density ) it allows you to wire the flex fuel sensor into the maf plug. Makes for a simple install. This will allow the chip to read the ethanol contant and adjust the parameters as needed. I would run a sensor in the rear of the car like I have and wire it from the maf plug to the back of the car. There are a few different ways I could do it as well up front if I didn't want to do it near the tank but I like the tank area better as you have more room to work with.
ThanksLimitedT,
This has to be used with the SD2 chip which is a MAFless speed density chip.
As for spark advance, from what i know and its not much about the SD2 chip it will add timing depending what the e85 content is. its not gear specific as it will just add additional timing across the board to your current set points.
maybe someone with more knowledge with the SD2 chip can chime in as for this info
Hope this helps some
No its not needed to have it linked. however you can if you go from e85 to e-98 or to 91 or a blend. car will run better when it knows the amount of e85. just getting the gauge will let you know alot.
