E85 with new stage motor
we4turbo
Hi all,
I'm am building a stage 2 on center block 260 ci, and would like to run e85.
I'm in the process of getting parts. I have the Red Armstrong double pumper
fuel pump, stock fuel lines, and razors 2 nozzle alky kit with my old 3.8 motor.
I also will running a gtq 74 turbo on the stage motor. I am looking to run the
120# or 160# injectors. Running e85 with the stock fuel lines and double
pumper support this set up.
Thanks,
David
I would go with larger fuel lines and better pump, cheap insurance for a stage motor. I have almost maxed out my 120lb inj with a big pump and lines with about 600rwhp.
Should I just go ahead with the 160 Injectors, or just mix some 87 gas blend and use 120# inj? I haven't bought the Injectors yet. I just emailed Eric the other day.
Can 160# inj be used with the stock emc with the upgraded drivers?
What is a good fuel pump?
Thanks,
David
I would go with the 160 if you plan on pushing that motor hard. Yes you could run them with a modded ecm. I went with a weldon fuel pump.
