egr
S
shag
Guest
I would likt to put my egr back on my Gn, but i have the champion iron heads, with the egr passage welded up.
can i drill this out?
and my intake was also modified the tower inside removed and ground smooth. the egr port was welded up too.
do i need a stock intake? or is mine useable?
The short answer is probably not. Way too much work to be done to get it back in operation.
so im better off to find a stock intake and heads if i want it to work again?
Why do you need it to work again? Emisson testing requirements?
