rookie_LC2
the name is...DOOmass
- Dec 31, 2003
Hi again, i posted earlier about charging problems with my new '87 T.
Bad alternator. Replaced.
I had a chance to look at the car this afternoon, there is still one more problem with it. The brake lights do not function. We checked the fuses, the grounds, bulbs, misc. wiring. Everything seems to check out. Went out to autozone to pick up a brake light switch, replaced that. No dice. Possibly the switch is not getting any power? We didn't have a voltmeter...
Is there an additional trigger on the master cylinder for the brake lights? I'm running out of ideas.
One more thing: when we replaced the brake light switch, there was one plug under the dash that was not connected to anything; covered in electrical tape. I removed the tape and saw that there was a bare wire jammed into the socket (not a paperclip) Does anybody have any idea what this cable is for?
-Its a loose cable, the plug is clear plastic.
thanks in advance for the help!
