lotzagoodstuff
lotzagoodstuff
- Dec 19, 2009
So I failed emmissions today, high HC (314 limit was 220). I had a very poor idle quality with the EGR plugged in, so I unplugged it and it ran better, however, it threw the "32" code.
So when I got back today, I manually engaged the EGR, and the car stumbled and almost died, which sounds normal. I decided to try to test the EGR solenoid, so I pulled the round cover off and when I removed the small air filter, the idle cleaned up and ran smoother. I put my finger over the EGR solenoid and again the car stumbled and almost stalled.
Here's my question: that little air filter, I can barely push or pull air through it with my lips. I believe this is prematurely opening my EGR, causing my poor idle quality. What's the risk of running the car back to emissions without this filter in place?
As always, thanks for the advice/tips.
