mkyledoyle
- Jul 19, 2022
I have a 1927 Ford Model T. My dad and I had it built back in the mid 90's. It has a Turbo 3.8L that was to go in the 1989 Turbo Trans Am. Other than a few niggly issues the car has be very reliable until a week ago.
I took it for a drive last week and it popped back through the intake a couple of times while accelerating. It had never done that. After that it continued to run and drive fine. As it usually did. I parked it in the garage after that drive. I went out a few days ago to take it out for a spin and it cranked but wouldn't start. I was finally able to get it to start but only by working the throttle. Once it started it was obvious that it wasn't running right because it wouldn't idle. the only way I could get it to stay running was if I held the throttle open some.
I checked for codes and it had set a 42. I went through all of the diagnostics for a code 42 check circuit 422 and 423 (if I remember correctly). By the results of that testing it indicated that the Electronic Control Module was the problem. I cleared the codes and replaced the Control Module. No Change. I have checked for fuel pressure and it is ~40lbs key on and with engine running (by me holding the throttle open a bit).
I'm not sure where to go from here. I do have a Matco 4000e coming later this week although I am not sure that is going to help.
Any help would be greatly appreciated.
