Street Lethal
Tech Anarchist
- Oct 8, 2006
"SA related in the bin he was using"...can you educate me here please? I am not a newbie however these are terms that I am not aware of.
SA is just the acronym for Spark Advance. If the problem is only happening under boost, and you are absolutely sure that the fueling is there during that boost, as well as the spark plugs, plug wires, ICM, etc, are firing properly, all sensors reading accurately, then it has to be somewhere in your tune. Not sure if disconnecting the battery might have done something in the bin as I have never run that setup, but it would be a good idea to ask the author of that code to look at the tune and see if there is anything off during boost pressure. If your friends are confirming fuel being removed a la low BLM numbers, then the timing may be off during boost leaving excessive fuel in the chambers leading to the symptoms you are describing; cut/sputter/misfire. You didn't mention a different cam sensor in the first post though when you were going through your testing, did you get a chance to try another one since you stated you already tried other ECM's and chips?
