Hi Guys, this is my first post sorry its a long one. I just recently had my engine rebuilt by Jack Merkel in Kennilworth NJ. He did a great job. I put 6000 miles on it and so far and not a single problem. This car is a daily driver in mint condition. I'm really excited about bringing it to the track this summer and I'm hoping to get a little input based on the current combo, est HP and 1/4 mile et's things like that. The rebuild included: Block bored on precision stand & 2 step torque plate honed. Speed Pro "plasma" piston rings. TRW forged pistons. Federal Mogul "Super Duty" alloy main and rod bearings.
Federal Mogul cam bearings. Speed Pro double roller timing set.
Comp Cams 206 206 and GM lifters. ARP connecting rod bolts, main studs. Balanced rotating assembly. Timing cover rebuilt with Speed Pro hi volume oil pump w/HD shaft Fully port cylinder heads. Machined w/3 angle seats, radius top cuts, machine valve guides for seals. Assembled with 1.77"/1.5" stainless steel Manley valves, hardened keepers, chromoly retainers, HD springs. Billet main caps on number 2 & 3 main journals. Bolt ons as follows: TA49, 55lb inj and XP double pump in tank, 65mmTB, CASv4, 3THDP, 2.5 ss exhaust, 9 Vigalante TC, trans rebuilt with all the good stuff, Eaton posi, all braces and busings as well as bilsteins on all 4. Nittos in the rear. Stock rims. All other work done by Rons Custom Autos, can't say enough about them. All input is appreciated ahead of time.
