Most current fuel hose has a liner to keep the alcohol from eating its way through.
However, on a stock-type pump/hanger unit which uses a connector rubber hose in the tank and it needs to be protected inside and outside, or it will go away in short order?
The last piece of submersible alky hose cost me $30 for a foot long piece, so you need to be sure to use the good stuff for reliability!
