Performance Parts for Sale:
Terry Houston 3" Downpipe with bung welded on for Wideband O2 sensor: $300.00
GT6152E Precision Turbo Brand New Run on car once for 10 minutes: $750.00
"Brand New" Razor Alky Kit w/ Dual Nozzle upgrade and the 3 Bar Map sensor: $500.00
Powerstroke Front Mount intercooler w/ aluminum end tanks and all piping: $250.00
Stock Intercooler: $60.00
Maft-Pro from full throttle w/ Extender Tuner Pro Chip and 60lb Mototron Injectors PACKAGE DEAL!: $750.00
Casper's Plug and Play wire Kit for the Maft-Pro NO splicing! $110.00
Innovate XD-16 LC1 Wideband O2 sensor Will connect directly to the maft-pro for Wideband tracking: $349.00
Casper's Fuel Injector Harness: $75.00
Billet FP regulator: $50.00
Stock Fuel Rail: $30.00
3" Maf Pipe Aluminized Silver in Color: $50.00
3" Uppipe Aluminized Silver in Color: $50.00
Full Set Front and Rear Bilstein Shocks: $240.00
Eibach Pro-Kit Lowering Spring Set: $240.00
Front Frame Braces: $30.00
Ported and Polished Stock heads with 100lb springs 5000miles since work completed: $400.00
87 109 Block 0.030 includes everything below the intake manifold and heads 5000 miles since rebuild: $800.00
(Rest of the engine parts are up forsale and can be included with the motor if you like PM me and we can work out a package deal)
Intake Manifold (Stock): $150.00
Stock Throttlebody with all new sensors: $80.00
Throttle Bracket: $30.00
Throttle Cable $25.00
Plenum: $25.00
RJC Power Plate: $40.00
Stock Valve Covers: $50.00
Aftermarket Valve Covers: $150.00
Stock Headers Welded and Reinforced: $150.00
Stainless Crossover Brand New: $100.00
Engine Wire Harness: $200.00
Stock Ignition Coil and Module: $100.00
2 Brand New Igntion Coils: $60.00 each
2 Cam Sensor Used: $50.00 each
Casper Cam Sensor Cap: $60.00
ECM: $100.00
BRF 200r4 Transmission and 3200 Lockup Stall converter fresh rebuild Art Carr pan: $800.00
TH400 race built for 800hp 3600 Stall Converter, Transbake, Lokar Stainless dipstick, Reverse Manual Valve Body,
and Hurst Shifter: $1500 OBO.
Guages GALORE!
VDO Gauges 2 1/16" With Sendors Boost, Oil Pressure(Brand New Sending Unit) and Water Temp: $100.00 Shipped
Autometer Carbon Fiber Series Guages 2 1/16" all NIB: Boost, Oil Pressure(Electric), Water Temp(Electric) and Volts: $35.00 each shipped
Casper Knock Gauge black face: $70.00 Shipped
Exterior and Interior Parts:
Wheel Well Moldings: $200.00
Black Out Trim for entire care: $200.00
Black Out Tailights (Driver Quality): $100.00
Headlight Bezels (Small Crack, Driver Quality): $50.00
Quarter Glass and Trim (Trim is chrome and is peeling a little): $150.00
Fiberglass Front and Rear Bumper: $120.00 each
Fiberglass Bumper Fillers: $180.00
Chrome 1986 T-Type Grill: $90.00
Black 1987 T-Type Grill (Has small crack on bottom edge): $50.00
Dash Pad No Cracks or Warping: Make Offer
Dash Speaker Cover brand new: $90.00
Guage Cluster: Make Offer
Have most interior trim and power accesorry door panels grey in color: PM your needs and an offer
Grey Good Condition no cracks Steering Wheel, Horn button and Ring: $150.00
Heat Only Setup Includes box, ducting and controls everything you need to put heat in the car without A/C: $350 OBO
All prices do not include shipping unless otherwise noted, if you want a part and you feel it is to expensive PM me an offer. I need this stuff gone ASAP to start a new project. I accept whatever form of payment you would like to use preferring Paypal and because of that will eat the 3% Paypal fees.
If you have any questions just let me know. I think this is everything and i combined it from some separate threads i had into one nice
convenient area so everyone knows all i have.
I have some more stuff in boxes i need to go through and will add to this thread when i dig it out of the garage.
Plenum: $25.00
ECM: $100.00
Guages GALORE!
