turbofabricator
- Mar 7, 2004
Well this is a first for me. I just got an on center Stage II with TA heads, Champion intake 274 cid up and running. It has a highly modified/detailed stock timing cover milled .125" to fit the on center block with a TA oil pump cover with -12AN feed, -10 AN outlet to filter and -10 AN from filer to block. It has. -6AN bypass line to the fuel pump block off plate. I am getting 125+ Psi on the gauge taken from the back of the block. The feed line attaches at the front side of the block. (Where the stock Turbo feed is on a 109 block, though on a StageII it is a 1/2" NPT) This pressure is at idle. Hot idle pressure is over 55psi. Bearing clearances are . 0022". The TA pump is a high volume version using stock style high volume gears. The end play on the pump gears is a trued .0005". With just approximately 1200 rpm on a drill motor it'll peg the oil pressure gauge. I talked with Nick to see if he has had an issue with the TA pump and he thinks it is because of the tight clearances in the pump and the efficiency of the TA pump cover. I would think that it should still bleed off what ever the pump can make. I have the shortest spring that is available in a pump kit and that did nothing. I installed a -8AN bypass hose temporarily into the valve cover and it filled the valve cover at idle. It also blew the o ring out of the oil filter causing Exxon Valdeze in the shop. (ever had oil dripping from your headlites? I must need to add blinker fluid now) I think that with the plugged oil holes in the timing cover and the blue printed oil pump clearances along with tight bearings and tight lifter bores the high volume pump is just too much? But GEEZE........125+psi at idle? No change with different springs? No change with an increase in bypass hose size? That TA pump is sure efficient albeit with out control of pressure. Any one have a suggestion? I am going to call TA and see what they say. I will either have to modify the pump to accept STD pump gears, buy a STD TA pump, or modify the bypass circuit to flow ALOT more oil.
