My car is having issues staying on or around the preset boost limit. I'm using one of those RJC controllers instead of the stock set up. It seems to work but I still get an extra 5 lbs of boost with some detonation every once an a while. I'm guessing the detontion is from to much timming since my car is only tuned for 15pi instead of 20psi. Anyhow, I hauled off and bought a Down pipe and Turbonetics Evolution ex-gate from Cotton. I'm looking to double check installing this in my Regal.
Now I'm guessing but I think I simply pull the aculator rod completely off the car along with the old DP? The aculator has a vaccum hose running from it to my controller...is this the line I used to plug into my external gate? The other end off the controler connects to my compressor side of the turbo.
Also, I've heard it's best to have the external gate close to the boost level that you have the car tuned for? ATM my setting is going to be 15lbs but my gate is set at 9lbs. My question, is this enough or should I shim the spring to gain a few lbs of boost? In the ner futur I plan on installing an Alky kit and pumping the boost up around 18-20psi. Will the same 9lb spring or shimed set up work for the extra boost or should I see if they make a high boost spring?
Thanks for all the help and opinions.
Ray
Ray
