Fast Clasic and other good parts
gczarny
fast is cool !
Hi everybody !
here is some parts I decided to sell off , all parts in good or like new or NEW condition , if I am not sure if the part is in working order I will not try to sell it ,everything extra for shipping and if you want to use PayPal add 3% of total for their fees , I prefer cashier’s check :
used ATR rear sway bar $150
OEM front sway bar $40
brand new Metco drive shaft loop $50
used with about 65k brake power master unit $150
set of used for less then 500 mls OEM rods with ARP bolt upgrade and pins $150
used for less then 500 mls complete FAST CLASIC fuel menagment system $800
used for less then 500 mls behives (blue ) roller springs and seats $99
hardly used direct replacement Pioner 4X10 rear speakers with brackets 120 watts 4 ohm $40
brand new set of G-body 2 “ drop front spindles $ 150
OEM cruise control servo $20
new 87’ brake master cylinder off NA Gbody -for vacuum conversion $50
2 used OEM cooling fans $20 each
used less then 2k mls 224 224 Turbo Buick Ductile Roller Camshaft $ 150
used less then 500 mls 218 212 Turbo Buick Billet Roller Camshaft $220
Full Throttle Expender Pro chip for MAF PRO $60
used but 90% good 2 Nittos NT555R 275/50/15 $180
RJC boost controler $30
new OEM ignition module and coil pack with bracket $180
used for less then 2k A1000 external fuel pump with speed control module and filter with 2 cartrages (one new in a box )and the fitting for OEM fuel rail to 10 AN $350
used OEM fuel rail with injector harness and Accufab adjustable fuel press. regulator $100
very new high valume front cover /water pump assy. $150
stainless crossover pipe for OEM exhaust manifols $50
stainless polished stock MAF to turbo pipe $25
new GM 3 bar MAP sensor $45
Flowmaster race muffler with welded cat. converter flange to use in it's place 3inch in/out $ 50
for any other info including pictures please Email me at .... evaczarny@sbcglobal.net ...... Greg
I'll take the boost controller. Just let me know your paypal info and total so i can send payment.
"new OEM ignition module and coil pack with bracket $180" Coil pack is new also? Both are OEM? Have they been tested good?
Will you do $200 shipped on maf pipe and module/coil pack combo?
Is this cast or aluminum?
