T Turbopoul Member Joined Jan 1, 2009 Jan 1, 2009 #1 How do you set timing on FAST ? With my oem computer i set it on 0 with the wire disconnected.
Chuck Leeper Toxic old bastard Staff member Joined May 28, 2001 Jan 1, 2009 #2 ?? Turbopoul said: How do you set timing on FAST ? With my oem computer i set it on 0 with the wire disconnected. Click to expand... Huh??? Maybe a bit of info on the application???
T Turbopoul Member Joined Jan 1, 2009 Jan 1, 2009 #3 XFI timing Its for Typhoon. Do you set timing on dash board the same as with timing light on balancer ?
H HighPSI Moderator Staff member Joined May 24, 2001 Jan 2, 2009 #4 You will need to have them match. You can either turn the distributor or adjust the crank referance angle.
