Hartline Perf.
- Nov 8, 2008
I just bought one, is a lighter spring necessary when you move it to the core support and if so, where do i get one? Is there a certain place it should be mounted that works better and how are you guys attaching it to the support?
A weaker release spring is recommended. You can find one in your local hardware store. Some guys have used a spring from a Pop Up Sprinkler. You will also need Fiberglass Struts or Weak worn out struts. The hood struts for a metal hood will be too strong.
